Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Fatigue Results in nCode › Reply To: Fatigue Results in nCode
Jeonee
You are right, but I try to say that the material's yield strength is 480 MPa, and when the fatigue analysis is done in nCode, I see that the result is 520 MPa, but the cycle is higher than 10^4 (almost 15737). In this way, due to 520 MPa, shouldn't the result be less than 10^4?
