Ansys Learning Forum Forums Discuss Simulation General Mechanical why calculations are the same for different load sizes or types Reply To: why calculations are the same for different load sizes or types
1617836513
Okay, thank you very much for your advice. I would also like to ask again, inside this self-designed screw simulation, such as screwing in a screw, or pulling out a screw, do I need to consider adding bolt pretention? If so, how do I set the amount of bolt pretention?
