Ansys Learning Forum Forums Discuss Simulation 3D Design Not able to create Force Monitor in Discovery 2024 R2 Reply To: Not able to create Force Monitor in Discovery 2024 R2
Shivaansh Adlakha
This is the error message after we selected the walls of the enclosure as the target instead of the body. When we were trying to select the body by triple clicking (it worked for the velocity monitor), it was not giving the check mark option for the force monitor.
Could the lack of output be because we chose the enclosure walls instead of the body? If yes what can be done now?
Also, for the drag coeffcient if I were to put the parameters in the formula would these be correct(Drag Force- Force I get from X axis force monitor?, Velocity- The flow inlet velocity? and density- density of air?)
