Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Different results with static and transient simulation › Reply To: Different results with static and transient simulation
If the velocity is that low the initial solution may be very similar to the converged solution, so residuals won't drop very far: read up on why. Are you running double precision? How much mesh are you using (resolution not cell count)? Why such a low speed?
