Ansys Learning Forum Forums Discuss Simulation General Mechanical why calculations are the same for different load sizes or types Reply To: why calculations are the same for different load sizes or types
armin.abedini
Thank you. Here are a few suggestions:
- To verify whether the torque magnitudes are being updated as a result of changing the Rotational Velocity, you can examine the reaction moments at the Fixed Support (drag-and drop Fixed Support onto the Solution branch after the solution is complete).
- I'm not sure if the Remote Displacement is necessary in your case since the screw appears to be well-constrained within the bone.
- Is your goal to simulate the whole screwing process with the screw penetrating into the bone? If so, explicit dynamics analysis, using Ansys LS-DYNA for example, might be a better option than the current implicit solution.
