Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth › Reply To: FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth
Whether to use one-way or two-way coupling depends on the degree of physical coupling between the fluid and solid solution fields. If fields are strongly coupled you can use two-way coupling otherwise one-way.
For one-way FSI you can import fluent results in MAPDL by direct schematic connection between the Fluent solution cell to setup cell of MAPDL. Please refer user guide for more information: Using Imported Loads for One-Way FSI (ansys.com)
Also, refer following tutorials to know the setup of two-way FSI coupling:
Analyzing FSI with ANSYS Fluent and Mechanical - Part I (youtube.com)
Analyzing FSI with ANSYS Fluent and Mechanical - Part II (youtube.com)
Hope this helps!
