Ansys Learning Forum Forums Discuss Simulation 3D Design Volume Extract Error Reply To: Volume Extract Error
Keyur Kanade
It is not clear from images. If it is completely closed chamber then you can use 'Combine' operation instead of volume extract.
You can find general procedure for fluid volume extraction in following video.
https://www.youtube.com/watch?v=Jp8btI0PCyU
One of the main reasons in failure is geometry errors. Please check geometry in SpaceClaim. Select geometry in structure tree --> Use right click --> Select Check Geometry. The geometry should be error free to proceed. If geometry has any errors, please modify/recreate geometry at those places.
Another reason is having some tangential contacts at some circular surfaces. Please make sure that bodies are intersecting instead of just touching each other.
Sometimes bodies are in contact only at some edges. At this point volume extraction may fail. In this case as well please make sure that bodies are intersecting each other.
During volume extraction some boolean operations are done in the background. If those boolean operations fail then volume extraction fails. In this case please check if you can use "Combine" command to "Merge" all solid volumes one by one.
You can check following videos on fluid volume extraction.
This video shows how to extract fluid volume of a cold plate in ANSYS SpaceClaim. Many different modeler commands in SpaceClaim are discussed during the course of this video. In addition to the plate, the fliud volume is also created for a cylindrical channel. Watch this video to learn more
www.youtube.com
SpaceClaim Demo of The Week - Extracting Volumes for CFD, MFG or Design - YouTube
Have you ever wanted to extract a solid from inside a part of assembly by filling in the empty space? Like taking a solid negative or pouring resin into a mold, but in virtual 3D. A tool capable of performing this task in mere seconds is a must for CFD, MFG fixtures and designing mating components. SpaceClaim's automated Volume Extract tool ...
www.youtube.com
You can also find some material on Ansys Learning Forum with following link.
Commercial Support Ansys customers with active commercial software licenses can access the customer portal and submit support questions.
forum.ansys.com
