Ansys Learning Forum Forums Discuss Simulation General Mechanical Cast iron model for Engineered cementitious concrete Reply To: Cast iron model for Engineered cementitious concrete
sai.teja.potu
@Onur gorur, did you manage to solve the issue with different slopes in tension and compression ? I'm facing a similar problem and would appreciate any insights or solutions you found.
