Ansys Learning Forum › Forums › Discuss Simulation › Fluids › hpc cluster shows error in journal file › Reply To: hpc cluster shows error in journal file
Luca B.
The warning "the rp-transition-model option is not available in this solver" indicates that the transition model you are trying to use is not supported by the solver you have selected in Ansys. This could be due to a mismatch between the features available in the solver and the requirements of the transition model.
What Fluent solver are you using?
How do you run your simulation with the cluster? I suggest you to try saving in local one dat file and restart from this one.
Luca
