Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › No wear analysis results › Reply To: No wear analysis results
July 25, 2024 at 7:39 pm
Please see the manual to make sure what cards are supported. It seems any contact type can be used if soft=2 (segment-based contact) is defined.Â
In your original post, you were reading k file and d3plot. You should be reading k file followed by dynain file. Please see the steps shown in multi-stage wear analysis at the end of the presentation. I cannot share the files of the example here but you can check the presentation to get an overview of the steps. For example, the LSPP command file below shows the steps taken using LSPP GUI.Â
