Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Single floating structure Ansys AQWA › Reply To: Single floating structure Ansys AQWA
July 25, 2024 at 4:26 pm
Shuangxing Du
The rotation unit of the mooring stiffness for the rotational motions in the aqwa output file is in [radian]. If you import this matrix into AqwaWorkbench for the connection stiffness matrix, please make sure the unit in Aqwa project for angles is in [radian] instead of in [degree]. Â
