Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure is not equal to the sum of static pressure and dynamic pressure. › Reply To: Total pressure is not equal to the sum of static pressure and dynamic pressure.
July 25, 2024 at 2:14 pm
To turn on local - you need to turn off global. Fluent will then scale the colourmap to the local (surface) range.Â
