Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Water Absorption in Porous Media – Ansys Fluent › Reply To: Water Absorption in Porous Media – Ansys Fluent
simone.iotti
I have tried instead to make just the sample and to set the water front starting from 5mm. I changed the initial theory model to Brooks and Corey and capillary pressure by Leverette-J by setting Leverette angle to 30°. Actually it does not match with my experimental data, but works. Otherwise, if i set Brooks corey also for capillary pressure, the front does not rise. It keeps still.
Best regards,
Simone.
