Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Help – I am confused by discontinuity/simulation not converging › Reply To: Help – I am confused by discontinuity/simulation not converging
Look for separation, ie stall. If you've followed the usual y+ guides you may find you need to refine the streamwise mesh too as flow cross inflation just sees high aspect ratio cells.
