Ansys Learning Forum Forums Discuss Simulation Photonics 2D grating phase calculation Lumerical RCWA 2023 R1 Reply To: 2D grating phase calculation Lumerical RCWA 2023 R1
giovanni.piscopo
Dear Amrita,
thank you very much for your answer! I will definitely read the article you sent me and implement the example that you linked!
Just as a additional info, I set the interfaces with this command:
“set(“interface absolute positions”, [0, h_wg, h_wg+t]);”
where h_wh = 1.3613 um and t = 0.1 um and automatically I got the interfaces set as in the picture I attached.
To confirm also the result, I calculated the refractive index distribution and I was able to see all the three indices of the three layers (actually about that I’ve seen that there is a bug in the visualization of the cross section because the thicknesses of the layers do not match the actual values but in FDTD there is no such a problem. However I’ve seen on another post on the forum that this is actually a visual bug that does not interfere with the simulation results).
Also, is there a difference in results between defining the interfaces between "reference positions" and absolute positions"? Because I find more intuitive defining them in terms of "absolute positions".
Thank you in advance
Regards
Giovanni
