Ansys Learning Forum Forums Discuss Simulation 3D Design Not able to create Force Monitor in Discovery 2024 R2 Reply To: Not able to create Force Monitor in Discovery 2024 R2
Devendra Badgujar
Hello Shivaansh,
Make sure you first go to Monitors Tab, select Force and than box select the geomtry and it will select the faces which you can the force monitor on.
Let me know if this helps.
Devendra
