Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Meshing Shell and Tube Heat Exchanger › Reply To: Meshing Shell and Tube Heat Exchanger
July 25, 2024 at 2:57 am
Okay I get you, so adding this heat is done in the setup after meshing I'm guessing. I have most of these parameters so that should be sweet. Thank you very much for the help, do you have any suggestions on the best way to mesh that shellside?
