Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Extraxt point coordinates from Design Modeler › Reply To: Extraxt point coordinates from Design Modeler
V.P
Hi N.M
If you want to export the coordinates of the blade at each span there is a tool called export points. This is available with a BladeModeler license. This will enable you to export all the points on the boundaries of cross section at different span levels.
Or else you might have to use the spaceclaim 'curve table' feature to extract the coordinates values of points.
