Ansys Learning Forum Forums Installation and Licensing Ansys Products unable to use Ansys workbench Reply To: unable to use Ansys workbench
23mce109
Ping request could not find host DESKTOP-4B67AV2. Please check the name and try again.
same error again.
the hosts file contained the following after i edited it.
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a ‘#’ symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1       localhost
# ::1             localhost
# 172.16.28.104 DESKTOP-4B67AV2
