Ansys Learning Forum Forums Discuss Simulation Fluids Different Static Pressure when reading steady result into transient case? Reply To: Different Static Pressure when reading steady result into transient case?
Dato
I got it. In order to have a single phase steady flow result to be patched as initial condition of transient multiphase flow, it's better not to switch off multiphase model and turn it on, which is what I have done. It's better to set the case under multiphase model.
Thank you for your helpful advice.Â
