Ansys Learning Forum Forums Discuss Simulation Fluids Asymptotic convergence check Reply To: Asymptotic convergence check
Scott Ormiston
As a follow-up: If the actual value of the report cannot be used as a convergence check, an idea we had was to do the check of the asymptotic
convergence in a UDF and then write a STOP file to the directory when the convergence is met.  Is there a better way to declare convergence using a UDF? The STOP file closes the GUI, which is not desirable. Can convergence be checked on a UDMI value?
