Ansys Learning Forum Forums Discuss Simulation 3D Design Creating a shell element with thickness and an inner part (corticalis&spongiosa) Reply To: Creating a shell element with thickness and an inner part (corticalis&spongiosa)
Atharv Joshi
Last video “Creating Periodic Blended Patches from STL in SpaceClaim” in the playlist Discovery SpaceClaim: Reverse Engineering – Ansys Knowledge covers STL to solid creation for similar use cases.
You can try the discussed method and check if that helps you resolve the issuse.
