Ansys Learning Forum Forums Discuss Simulation Fluids Mass flow inside a specific volume Reply To: Mass flow inside a specific volume
If you already have a steady result you can look at area on the top (lid) with +/- flow. You can also create an iso-clip surface to show the area in/out. That will give a flow rate, but may not tell you how much material enters.
