Ansys Learning Forum Forums Discuss Simulation Fluids Different Static Pressure when reading steady result into transient case? Reply To: Different Static Pressure when reading steady result into transient case?
Dato
Yes! I disabled multiphase model to run steady flow and write .dat file, after which enabled multiphase model. Then read the .dat file. It is time that the situation occurred. I didn't change operating density. According to Fluent user guide, operating density needn't to be cared  because density is temperature dependent and hence Fluent would ignore it.
It sounds like something unknowable had happened internally when setting multiphase model. Well, thank you Dr Rob. It's quite a noteworthy experience that cannot to get in Fluent manual.
