Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Mass flow inside a specific volume › Reply To: Mass flow inside a specific volume
Given the forum downtime it's possible the thread was lost.
If you add the cooling gas as a different species (same properties as the bulk) you can monitor volume fraction inside the vial volume. You'd need a separate fluid region for this. Surface reports may not be overly useful as volume entering the vial will displace volume leaving although you could monitor +/- area or similar.
