Ansys Learning Forum Forums Discuss Simulation General Mechanical Simulations of forces in a steel bend restrictor Reply To: Simulations of forces in a steel bend restrictor
Eigil Reppe
Thank you so much for your answer,
After both moving it in CAD and adding a damping factor, and making my contacts frictionless, my solution converged.
The structure was loaded with a moment on the faces furthest away from the "wall".
