Ansys Learning Forum Forums Discuss Simulation Fluids UDF loading error Reply To: UDF loading error
fakhreddine.madi
I just managed to solve the loading error. I had to open Fluent using "x64_x86 Cross Tool Command Prompt for VS 2022," and I compiled the code without using the built-in compilers. Then it seems to have loaded normally now. I will still need to check the code functions correctly. What do you think might have suddenly caused this?
