Ansys Learning Forum Forums Discuss Simulation Fluids Different Static Pressure when reading steady result into transient case? Reply To: Different Static Pressure when reading steady result into transient case?
Dato
I need to run transient simulation. I solved flow and turbulence equation in steady flow and used it as initial flow field in transient. I'm just using default water-liquid with temperature dependent density and it's a single phase flow.
Sorry that I'm not exactly understand what "Assuming both are solved solutions?" means. Flow field has converged in steady flow.
