Ansys Learning Forum Forums Discuss Simulation 3D Design WELD in SpaceClaim Reply To: WELD in SpaceClaim
Atharv Joshi
Hi Appo,Lucas
You can create a spot weld between 2 solids. Weld surface is not possible between 2 solids.
You can weld surface bodies to other surface bodies or to solid faces.
Try to create mid-surface first and then select the weld tool.
Thanks and Regards
Atharv
