Ansys Learning Forum Forums Discuss Simulation Electronics SIwave Current Density Analysis Reply To: SIwave Current Density Analysis
Mrinmoy Bharadwaj
Thanks for Sharing the image your set-up. As I mentioned, AC/Frequency-dependent sources can be assigned in SIwave and current density can be viewed. Either you define your current-time data as an input to the frequency dependent source OR use the push-excitation workflow for doing the same wherein you will define your excitations in the Ansys Circuit designer and push excitations back to SIwave.
Additionally, such analysis can also be done in HFSS Classic and HFSS 3D Layout where you can view current densities in the planes.
