Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two-way FSI: It’s impossible to simulate a cantilever discharging pipe in Ansys › Reply To: Two-way FSI: It’s impossible to simulate a cantilever discharging pipe in Ansys
Rahul
You can specify, the number of cores to be used for each participant as a fraction of the total cores in the system coupling GUI.
RMB Coupling participant > Parallel solve setup...
Provide total cores to be used. Here in this example fluent will use 8 and mechanical will use 4 cores.
Please refer user guide for more details: Using Parallel Processing Capabilities (ansys.com)
