Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Workbench update design points does not update › Reply To: Workbench update design points does not update
mjmiddle
If you turn on the messages in workbench ("View > Messages") what is the error where a Design point fails? Are you running through Remote Solve Manager (RSM)? You may try resetting the Ansys cache to all defaults. Type %APPDATA% in the Windows search field, which should take you to a folder such as:
C:\Users\{login}\AppData\Roaming
Go into the Ansys folder and delete or rename the Ansys version folder while all Ansys products are closed. For Ansys 2024 R1, this would be v241.
When you launch Ansys the next time it will write all defaults to the location.
