Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence problem when going from 2023 R1 to R2 Reply To: Convergence problem when going from 2023 R1 to R2
Simon-Olivier
Thank you for the reply.
I compare the ds file for a very simple model and the only change is my node numerotation and I don’t know why (same number of node/elements/quality statistics…).
Also, the change in the global matrix formulation stays the same:
  • With 2023 R1 version, tsymmetric global matrix
  • With 2023 R2 version,non- symmetric global matrix
But this time, since the model is very simple, I can get a solution in the 2 cases.
Is there a reason for matrix symetric/non-simmetric?
Thank you for your help
