Ansys Learning Forum Forums Discuss Simulation Photonics Calculation of electric field profile through Lumerical FDTD Reply To: Calculation of electric field profile through Lumerical FDTD
Amrita Pati
Hi Debasish,
Are you looking at the extinction cross-section and the electric field intensity from the same run (of each separation)? I would expect the field intensity at the smallest separation to be maximum. When you say that a slightly higher separation has the highest intensity, does it mean that you see a lower intensity for the smaller gap?
Amrita
