Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT porous zone solid temperature problem Reply To: FLUENT porous zone solid temperature problem
You did read the documentation section that explains porous zones aren't effected by radiation as Fluent doesn't "see" the metal in the zone? Also, that the solid and fluid are the same temperature unless you used the non-equilibrium option?
