Ansys Learning Forum Forums Installation and Licensing Ansys Products Issue with Inlet Pressure in CFD Simulation of a Laval Nozzle Reply To: Issue with Inlet Pressure in CFD Simulation of a Laval Nozzle
How much lower, and as the inlet is Total pressure have you checked that? Has the solution converged? Depending on how you initialised the model you may not be seeing the final result for a fairly high number of iterations.Â
