Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Suddenly divergence in transient simulation with VOF › Reply To: Suddenly divergence in transient simulation with VOF
July 22, 2024 at 9:29 am
For a single phase model 5 cells across the tubes would be considered coarse. If you expect vapour there too you need a lot more mesh. With a fixed temperature the liquid should reach that value, as will the whole domain in time, that's probably not the intended result?Â
