Ansys Learning Forum Forums Discuss Simulation 3D Design Spaceclaim block recording Reply To: Spaceclaim block recording
Keyur Kanade
Typically, when you close blocks and then perform some operations, if you open the blocks again and find it empty, it suggests that the operations performed while the blocks were closed were not recorded. If you want to perform operations without them being recorded in a block, you would need to ensure that block recording is turned off during those operations. To manage block recording, you can turn it on or off as needed. When it's off, the operations you perform won't be captured in the blocks. Remember to turn it back on when you want to resume recording operations in blocks.
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
