Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How Fluent calculate saturation temperature in Lee model? › Reply To: How Fluent calculate saturation temperature in Lee model?
Dato
Yes, I found that Fluent would automatically handle and there is no need to set operating pressure to zero. And in my case, I think that density is specified as piecewise-linear temperature dependent so there is no need to specify to zero.
Hold on, you said that"you may find setting operating to zero to help with other elements of the model. " Do you mean it will help that zero should be set when using the Lee model or the VOF model? I know that in some aero flow cases with high pressure drop, it should be set to zero.
Thank you sir.
