Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › AWAN simulated floating dock › Reply To: AWAN simulated floating dock
Shuangxing Du
Please check if the structure of the rear side wall is fixed by a fixed joint in the time domain analysis.  If the meshes and joints are all symmetric with respect to the central vertical XZ plane between floating docks, the results should be symmetric.
