Ansys Learning Forum Forums Discuss Simulation General Mechanical Management of Participation Factor Reply To: Management of Participation Factor
ErKo
Hi
There is also a native setting in wb mechanical and a harmonic response system (MSUP – so modal MSUP harmonic response). It is under analysis settings and is called:
Mode Selection Method – set that to Modal Effective Mass and then set a threshold for the Ratio of Effective Mass to Total Mass (so if set to say 0.2 it will take modes with a Ratio of Effective Mass to Total Mass higher than 0.2).
See here for more info on the above:
Coupled Field Harmonic, Harmonic Acoustics, and Harmonic Response Options (ansys.com)
See here how to aview the above help link:
https://innovationspace.ansys.com/forum/forums/topic/how-to-access-the-ansys-online-help/
