Ansys Learning Forum Forums Discuss Simulation Photonics FDTD transmission fluctuation Reply To: FDTD transmission fluctuation
Greg Baethge
Hi NAMHYEON, these oscillations are not necessarily wrong: as your substrate has a finite thickness, you basically have a Fabry-Perot cavity. You can easily check this using the STACK solver (see stackrt script command)
