Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Fluent › Reply To: Fluent
July 18, 2024 at 4:35 am
I am using steady state continuous and DPM phase simulation. I am injecting the particles after the continuous phase has reached convergence, the moment after injected the particles in few iterations k and epsilon values becomes very high and getting floating point exception error. i cant proceed further to run the simulation. i am using mass flow inlet and pressure outlet BC. DPM - mass flow rate of particles and velocity calculated for the inlet boundary provided. I am using eulerian granular option. I dont see any volume fraction at outlet as the particle injection are given afterwards. Could you clarify what is ansys rocky?
