Ansys Learning Forum Forums Discuss Simulation General Mechanical How to connect two nodes (Ansys workbench) Reply To: How to connect two nodes (Ansys workbench)
Asitang
Scoping of nodes or vertices is allowed only on the contact side of a contact pair; thus, the Target field turning yellow indicates an invalid assignment. To create a continuous and conformal mesh with shared nodes between the mating parts, you may consider implementing share topology at the interface using Discovery/SpaceClaim.
Hope this helps!
Asitang Lahurikar
