Innovation Space Logo
FREE STUDENT SOFTWARE Login
  • Community
  • Learning
  • Support
  • Educator
  • Career
  • Maker
  • AnsysGPT
  • Learning Forum
Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Delamination not occurring in an End Notched Flexural Modal › Reply To: Delamination not occurring in an End Notched Flexural Modal
July 17, 2024 at 6:45 am
Ashish Khemka
For the messages you encountered:
  1. Fracture Parameters Incorrect:
    • This warning often indicates issues with the calculation of fracture mechanics parameters. Ensure that the crack tip nodes are not attached to unsupported element types. You might need to remove contact elements at the crack front if they are present.
  2. Contact Status Abrupt Change:
    • This warning suggests that the contact status is rapidly changing between “closed” and “far open” without passing through "near open". You can try reducing the time step size or increasing the pinball radius to stabilize the contact status2.
  3. Reference Convergence Value Less Than Threshold:
    • This warning indicates that the reference convergence value is very small, which can happen when applied loads are minimal. You can override the minimum reference value by specifying it under the nonlinear controls of the analysis settings.
  4. Small Equation Solver Pivot Term:
    • This warning usually points to a numerically unstable model, often due to large deformations or insufficient constraints. Ensure that your model is properly constrained and consider refining your mesh or adjusting the solution method.
Ashish Khemka
Connect with Ansys
  • Legal Notice
  • Privacy Notice
  • Cookie Policy
  • Export Compliance
  • Terms and Conditions
  • Report Piracy
  • Forum Rules & Guidelines
  • Site Map
© 2026 Copyright ANSYS, Inc
Please Login to Report Topic
Please Login to Share Feed
Ashish Khemka
Cancel Save Reply as Draft Publish
Edit Discussion
Avatar
Ashish Khemka
Add Tags
Cancel Save Draft Publish
You are navigating away from the AIS Discovery experience
Proceed
Continue
Ansys Assistant
Welcome to Ansys Assistant!
Login
Ansys Commercial Customers: Go to AnsysGPT
Your chat history is not stored
Hey there, you are quite inquisitive!
You have hit your hourly question limit.
Please retry after '10' minutes.
For questions, please reach out to ansyslearn@ansys.com.
RETRY
Are you sure you want to leave? The window will be closed.
OK
