Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Does Nonlinear Mesh Adaptivity in WB support ANISO material by command snippet? › Reply To: Does Nonlinear Mesh Adaptivity in WB support ANISO material by command snippet?
Asitang Lahurikar
The error message indicates that the Nonlinear Mesh Adaptivity (NLAD) feature is not compatible with anisotropic materials. Ansys Help for 2022 R2 version discusses some materials that are not compatible with NLAD; however, you can refer the most recent documentation for more details on material models that are compatible with NLAD - 2.3. Nonlinear Mesh Adaptivity Requirements and Limitations
Hope this helps!
Asitang Lahurikar
