Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ANSYS fluent – Rocky DEM coupling › Reply To: ANSYS fluent – Rocky DEM coupling
July 16, 2024 at 8:58 pm
Thank you for your reply and help.
my case is a mixing tank with no baffeles and a tilted impeller which then I will use it as my case file for Rocky. Attached is the mesh and the the velocity contour with node values off as you mentioned in the previous messages.Â
can you please let me know what do you think about the mesh and the velocity gradients? Do you think the simulation results are acceptable ?
I have also attached a report definition of the epsilone volume average. (these are results before transfering to Rocky)
