Ansys Learning Forum Forums Discuss Simulation Preprocessing Topology does not match the blade profile Reply To: Topology does not match the blade profile
rfblumen
If you have defined the geometry in BladeGen, I would use the following approach to generate a TurboGrid mesh from the BladeGen geometry:
-In BladeGen, go to File->Export->Neutral Data File.  Save the resulting NDF file in the user_files forlde of the WorkBench project
-Drag out Geometry from the Toolbox in WorkBench and open DesignModeler.  Use the BladeEditor icon "Load NDF" to load the Neutral Data file that was just generated
-Drag out TurboGrid from the Toolbox in WorkBench and attach it to the Geometry cell that was just created.  Generate the mesh in TurboGrid
This is the most accurate approach.Â
