Ansys Learning Forum Forums Discuss Simulation LS Dyna CONTACT_TIED Reply To: CONTACT_TIED
wissem chakchouk
Hello
I have the same problem: I want to share the nodes for these two parts (blue and red), which options I can use Contact_surface_to_surface or Contact_node_to_surface and what is the difference between them in the results.
Also, I have no idea how to change the settings of this module and what the main settings are(These settings as it shows is by default).
Thank you in advance.
