Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Tau Clone Mesh failure › Reply To: Tau Clone Mesh failure
July 16, 2024 at 4:05 pm
The error is likely to be caused by the "small feature on Matching boundary". To find the object with problem, you could non-model the rotor, stator and other parts that touches the boundary one by one to see when the model can be meshed and run. Then you can simplify the geometry of the object like replace the curves at boundary with segmented polylines, and mirror the object to make sure its geometries at the matching boundary are excatly the same. Similar issue is often seen in 2023R1. 2024R1 and R2 version are more robust for this issue.
GL
